Is this possible?
http://www.gotstang.com/profile.php?...STGATOR&info=1
Is this possible?
It should be more like in the high 14's
By Bill Putnam from Modular Depot
1.) Power – If you listen to some old school drag racers they may say you need at least 300+RWHP to hit 12’s in most cars. In some heavier cars that may be true but fact is suspensions are more refined these days and cars don’t weight 4,000 lbs. Most PI headed cars will hit the 245-255RWHP mark with basic mods (Pulleys, Timing Adjuster or chip, O/R H or X, K&N or other type of high flow filter and although not a power mod…gears 4.10s or 4.30s). For a bolt on GT this is enough power to get the car into the 12s after you follow the other steps. Keep in mind more power will make it easier to reach your goal or help offset more weight (see next section) but it can be done with less.
2.) Weight - You basic 5 speed coupe without driver weights 3250lbs. So with an average driver weighing about 180lbs that puts your race weight at 3430lbs. At that weight and a power to weight ratio of .075 you would need 258RWHP to hit 12’s. Power to weight is the power of your car (rear wheel) divided by race weight of the car. Using my car when I broke into the 12’s first time I was making 246RWHP and had a race weight of 3250lb, which worked out to a .075 power to weight ratio or .075RWHP per pound of the car. From what I’ve seen a car can get into the 12s with a .075 to .080 P/W ratio. So if your race weight is 3430lbs then 3430 * .075 = 257.25RWHP. As long as you keep this ratio in the .075 to .080 range you are fine plus keep in mind you can drop weight instead of adding power. An example of this is a car with a 3000lb race weight could break into the 12s with 225RWHP (close to stock power on a GT).
18" x 9" Boyd Coddington Fury Wheels
Toyo Proxes 285/35/18
Accufab Intake Plenum
Accufab 75MM TB
C&L 80mm MAF w/ K&N Filter
C&L Power Pipe
March UnderDrive Pullies
FR 3:73 Gears w/ SpeedCal
Steeda Tri-Ax Shifter
Steeda Springs
UPR Billet Accessories
UPR Yellow Carbon Fiber Gauge Insert
Bassani X-Pipe
Borla Exhaust Steeda 3" S.S. tips
Dallas Mustang Grill Delete
Let me help you clear something up that was my fastest time at the track. When my car was dynoed two years ago it was with out that blue baby bottle in the trunk. I must have miss read what they were asking but that is the reason for the confusion. Sorry motor times are 1\8 8.756 79.36mph 1\4 13.750 97.43 mph
I don't think that is possible with just at amount of hp. 238hp probably will get you into the low 14's perhaps but not 12's. Your about 150 hp short.
Post up your timeslips from the dragstrip.
Matt
what are your torque numbers? what rear end ratio are you running? what tranny? any mods for increased traction?
too little rwhp for that time
Check out AutoBadges.com's Demo Vehicle!
Looking for a Mustang Part, Email Me I Have Sponsors To Help!!
he had nitrous.
MODS:Stereo:
Pioneer DEH-P4600MP MP3/WMA CD player
Infinity Reference 6x8s All around
Performance:
Cold Air Intake
215/65R15's BFGoodrich Traction T/A's
Interior:
Indiglo Gauges
Nice!
466RWHP 490RWTQ
Magnaflow Cat-Back, UPR O/R X-pipe, K&N FIPK
2.76 Non Slip S/C Pulley
4 Peice Idler Set 3 100mm 1 92mm
Gates 74.5" Belt
NGK TR6 Plugs
SCT Multi Chip Package Custom Tuned By Herman
GSMC#1
I am a and I am definately a
Show me a time slip with your dyno sheet attached and I'll still be skeptical..No, actually, I'll still say you're full of it.
I've run next to cars many times that make damn near that power to the wheels and they turn 14.4 to 14.6 all day long, every day. Never in my life have I seen a car capable of 12's that couldn't get to 98mph at the traps.
I don't feel too close minded, am I too far off the mark here? We're talking ~285 hp at the flywheel here.
NoSlo5.0 I am with you.
No except very few and I mean very few read whats posted they just see what they want to see. This has aready been cleared up once but for a sec. time to those who couldn.t figure it out the first time THE DAMN CAR WAS NOT DYNOED ON SPRAY BUT WAS RAN ON SPRAY IN THE TIME SLIP BUT STILL I POSTED MOTORS TIMES ALL YOU HAVE TO DO IS SCROLL UP AND YOU CAN SEE BUT IT IS IN THE 13' S NOT 14'S ON MOTOR AND I HAVE THE SLIPS AND DYNO SHEET BUT IT IS'T HARD TO BELIVE A STOCK MUSTANG WON"T RUN 13.75 WITH BUILT TRANNY GEARS ET>DRAG AND BOLT ONS
And anybody is welcome to come get some cuz it might be slow but it is deadly consistent and runs the exact same numbers on the street as the track
AND YES I MIGHT JUST Be A JACKASS but i know what my car runs
Yep, didn't see that, sorry. With sticky tires they're in line. Don't wanna talk to you no more...Originally Posted by LIL_INSTGATOR
Now who's the jackass?
j/k
Originally Posted by 95mustang302
I have 241rwhp and run 13.8x's!
WHIT
2000 GT M5
+Dragon Intake Plenum w/FRPP 70mm TB
+Magnaflow Catted "X" pipe and CatBack w/3.5 in Tips
+Steeda Tri-Ax/LCA's
+Steeda Splitter
+Bullit brakes
+FRPP "C" springs/Aluminum D. S.
+Tokico 5-ways
+Cobra R Hood
+Y2K Cobra R wheels
+One of 100 Mustangs with FR 500 Seats
8.950@81.57
13.850@100.2
Daily Drivers:
02 Harley Davidson F 150 #6548
02 SVT Focus #3601 of 4788
I ran 13.77 @ 101 with around that I guess. I never had my car dynoed though.Originally Posted by Tacbear
It had the pi intake and an exhaust and 4.10's with the steeda T/A and pulleys.
Kumho's traction = teh not present.
Got Stang Import Crew Member #1
