ok i have a c&l 76mm mass air meter ordered for my 19lbers...well i was just told that i cant use my already installed cold air fender mount with it??? cause of the bend in the tube, they said it will cause rough idle and wont run right and i would loose power...so do any of you have this same setup?? they told me the only way i could use it is if i used my factory air box with the silencer removed...which i sold when i bought the cold air kit.
