I'm looking to trade my '89 turbo Mustang coupe project for a '93 and up Cobra. I work in Afghanistan and don't have the time to put this car together and enjoy it. It comes with the best of everything. I just need a car to jump in and drive when I come home every 4 months. Here's what you get...
Body:
Candy Tangerine Orange
Straight No Dents
Has white stock hood
Inner fender wells have been cut for twin turbos by pervious owner
Chassis:
Front-
Granetelli front tubular k member
Granetelli tubular a arms
Granetelli front coil overs
CE 90/10 struts
MM adj. caster/camber plates
Flaming River manual rack steering kit
Manual Brake kit
5 lug conversion on front
Rear-
8.8 rear with 3.55 gears
Mini tubbed
CE anti roll bar
CE rear coil overs
CE drag shocks
HPM upper & lower control arms
CE subframe connectors
HPM driveshaft safety loop (new in the box)
Interior:
Grey interior
10pt roll cage
Painless wiring kit
Needs front seats (have some that would have to be redone)
Misc. Autometer gauges
G Force 5 way belts
Engine:
Coast High Performance 347 shortblock
Balanced bottom end
Block bored .030, lined bored, clearanced
New bearings
Blueprinted HV oil pump
Canton main girdle
Canton oil pan, pickup tube, windage screen, scraper, dipstick tube
ARP Main Studs
Comp Cams Solid Roller custom grind cam for this turbo
Comp Cams Solid Roller lifters
Edelbrock Victor Jr heads 70cc with o ring groove bare
Probe shaft rockers
Edelbrock Super Victor Jr carb intake
Carb Shop 850cfm blow-thru carb
MSD Pro Distributor and coil
MSD 6AL and MSD boost timing box
Aeromotive A1000 fuel pump
Aeromotive boost fuel regulator
All s.s. braided line for fuel and turbo
Misc. new Earl’s AN fittings
HPM 1” drop solid motor mounts
The motor still needs to be assembled
T-76mm Innovative R trim ball bearing turbo
Custom Headers
4” Hot side with Dynatech muffler
Jet Hot cold side for non intercooler
Have an intercooler from a F350 to throw in
Turbonetics Godzilla Blow off valve
Turbonetics Delta Gate wastegate
EV polished carb hat with EV polished divided spacer
Griffin Radiator
Transmission:
Tremec TKO
Lakewood Bellhousing
Pro 5.0 shifter
Spec stage 3 clutch and pressure plate
Billet steel flywheel
Adj. clutch cable and quadrant
Custom Driveshaft
Energy Suspension trans mount
I have more parts that I’m forgetting to list. I’ll be throwing them in with it. I’m currently in Afghanistan, and have no time to put this car together. As you can see, I have a lot of money tied up in the car. Assemble this car and run 9’s…
Can provide pix. Please email me your email address and I'll forward pix to you.
