gotstang.com forums logo
back to gotstang.com
Results 1 to 3 of 3
  1. #1
    ulvdemon is offline
    Gotstang? Newbie!
    Join Date
    Jun 2005
    Location
    Lithonia GA USA
    Posts
    19
    Default Headliner Question
    Unknown if this is the place to post this and I tried to look it up in the search function. Does anyone know of the best way to repair the ceiling headliner in my '02 Mustang? It looks like mine is sagging near the rear window and I can't seem to find a way to repair it. Thanks for the help all...
  2. #2
    slvrbullit331 is offline
    Nitrous Junkie slvrbullit331's Avatar
    Join Date
    Dec 2005
    Location
    Alabaster AL USA
    Posts
    12
    Default
    You should be able to pull all the lighting and interior moulding and remove the headliner. Then in the areas that it is sagging spray some contact adhesive on both pieces and bond them back together and reinstall the lighting and the moulding.
    1995 Mustang GTS Opal Frost
    DSS 331 Stroker 28oz balance, RPM Heads, Intake, NOS Big Shot Plate Kit, Comp Cam, 1.7rr, MAC 1-3/4" LT's, Dr. Gas 3" X-pipe, MAC Cat Back, SPEC Stage 3 Clutch and Billet Steel Flywheel, Stock T-5, Detroit "C" Locker rearend, Moser 31 spline axles.
    12.30 at 110 N/A
    11.43 at 119 150 Shot
  3. #3
    ulvdemon is offline
    Gotstang? Newbie!
    Join Date
    Jun 2005
    Location
    Lithonia GA USA
    Posts
    19
    Default
    Thanks for the help, I will give it a try.
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
