Need help to figure out temp problem on intercooler. Normally temp is about 130, even on hot days. Now when it is driven temp climbs to 160+. When the car is not moving and engine is at idle the temp comes back down to normal. Fan is running, you can feel the pump is running, has anti-freeze in it. Someone told me the plastic peller in the pump may be worn down. I'm not a mechanic by any means, some help would be nice.
