91 5.0 performance parts
I have a ton of 5.0 performance parts for sale, if anyone is interested message me...
5.0 block needs machining and needs sleeves for sure! very cheap
GT-40p heads with 1.6 full roller rockers, and 390# springs, ready to bolt on
pushrods and lifters
Trick flow street burner intake, upper and lower
Comp cam xtreme energy stage 1 cam (gives .512 valve lift when used with 1.6 rocker arms)
pypes shorty headers, have been used and has broken bolts in the flange, but selling very cheap
greddy type s blow off valve
powerdyne 5-6psi supercharger and bracket, with crank pulley and spacer, some bolts are missing
factory e-7 heads
ford racing chrome tall valve covers
c&l 73mm mass air housing calibrated for 24# injectors
24# injectors, needs o-rings and pintle caps
factory fuel rail with fuel pressure regulator attached
professional products high flow fuel rail with adjustable fuel pressure regulator, NEEDS ALL NEW O-RINGS
original LPH fuel pump, about 2 years old, works great, very cheap
water pump and timing cover
original hood, black paint, in very rough shape and beat up, also very cheap
other parts as well, write me with questions about price, i will ship to you, and will accpet paypal
do you still have the gt40 heads and how much
What are you asking for the blower ?
