http://store1.yimg.com/I/mustangtuning_1826_1708736
OEM ford mach 1 grill delete
http://store1.yimg.com/I/mustangtuning_1828_11919696
Rear end rebuild kit w/ bearings to install 4.10's :D
that kit is from MustangTuning right? that's where I got mine from and i'm ver pleasedQuote:
Originally Posted by Joe Friday
I'm glad to see the grill delete in there, I think it makes a huge difference. 4.10's, you doing that yourself?
Yeah its from mustang tuning. I bought the frpp gears from them and everythign went somoothley so I went back for my mach 1 grill delete. I'm taking it to a local shop to have it done where they will let me help with the install. They have all the equpitment and such so I wont have to buy/rent/find someone with a micrometer to get the proper pinion to ring clearence and everything :D
When the Tax refund ( $950) I'll be getting new tires, sub frams, strut tower brace and springs :D
what does the rear end barrings do? Is it worth buying if you are going to redo the gears? And what about IRS brushings and what not?
Quote:
Originally Posted by My Cobra
Yes, if your have the rear end dissasembled then it's worth changing out the bearings. I've heard people haveing bad bearings at 30 k miles. so might as well replace them since all that shit is going to be out of the car anyways.
And the GT's don't have IRS. But if your already messing with the rear end, might as well replace those rubber bushings :D
