Thanks for the info! I won $450 for the superbowl. I am stoked. :woohoo:Quote:
That was the first thing I read when I got in this morning. It gave me a headache.Quote:
Originally Posted by thumpin347
There's the torque arm!Quote:
Originally Posted by Js281GT
safe tune and i am still only 3rwhp away from 400. i would like to work ona 5.0 tho, seems easy.Quote:
i wouldnt say its easy...depends which route you want to go. i prefer building motors, and motor combinations whereas the mod motor guys can only resort to forced induction because of lack of aftermarket goods. theres alot of formulas for pushrod 302s...so in that sense, its easy...to build a good motor, on the other hand isnt that easy...and it also depends who does your work...Quote:
Originally Posted by Junior2561
if you write checks, then of course its easy, just pick your parts and drop the car off...i like to do all of my own work, so its far from easy
lol nice stang pics
whoQuote:
Originally Posted by Fastest302
My favorite combo is a 331 stroker afr 185 & cobra intake. The holley system max 2 is pretty sweet too.
putting a cobra intake on top of a built 331 would just restrict the motorQuote:
What about trick flow or GT40? My buddy has a 347 with ported victor juniors & an aggressive cam. He is saving for a turbo kit. He want to hit 9's :j:Quote:
My Cobra lower is ported and my upper is extrude honed, it works okay on my 347. A systemax would be better. I'm a slave to the looks of the Cobra on my year car. I'll deal with the restrictions. The lower can actually be made to flow quite well for 302 engines. It just isn't enough for strokers. The GT40 uses the same lower, it sucks worse than an extrude honed cast Cobra.
With ported Vic Jr's, you need a short runner high rpm intake to match. The 347 makes a lot of torque, it would be best to gear the rear with 3.73's or 4.10's and use a victor efi intake to go with them. IMO of course.
werd, what NoSlo said...go with the victor intake. what kinda block is that 347 based off of? if its a production block, tell him to sell if off as a shortblock. if he really wants to hit 9s, i say go with an R-302 or A4 or dart block, bore it .030" (306c.i.) built for hi rev(7k+rpm) with a jericho 3 spd., or C4 based tranny w/ transbrake, 4.10s and boost the shit out of a T-66 or bigger with a DFI or equivalent management unit....thats the speed formula for a 9 second street car
He has the a4 4 bolt main. It is scary in his car he has stock suspension & brakes. he doesn't even have his subframes on the fricken thing. We all know five oh's handle & brake like shiznit at high speeds. He is putting in a cage before he does any suspension.
My dad has a 1965 Ranchero (3400lbs) that was running high 11's with a 289 and a 4 speed back in the early '70's. It currently has a 351c with a C4 and runs 11.0's. The thing about the car is that you have to push it down hill when it's in neutral. Once we fix whatever is dragging, it will most definately be a mid to low 10 second car.Quote:
Originally Posted by TheSickness
the 302 is as old as dirt so there will be more ways that are well know to get the 302 in the 10's so in a couple of years the same things will be out there for the 4.6 all motor poeple a couple of years ago there was not a all motor 4.6 in the 10's and know there is so give it 2 years and it will just be an every day thing
Your stangs are all faster than mine, because MINE IS :censored:ING STOCK!
