If my parents were to buy me a stang... I sure wouldnt stop them. LOL
from someone whe's done more work on HER car than you can ever dream of...Quote:
Originally Posted by joe friday
:fu: U
you don't know shit
:lol: >owned<Quote:
Originally Posted by Nicoleb3x3
:rofl: HA! I hope that you're not implying that you've personally done more work on your car than I have on mine or anyone else for that matter.
If you think that's the case you better keep on dreaming sweet heart. I read along with your "uber" complicated 2.3 to 5.0 conversion, that stuff is child's play, you pulled out an old motor, and bolted on some headers, then and on top of that you took it to a shop finish up your mess and fix your junk trans. It's okay though, I didn't expect you to actually complete a project like that on your own.
I hand built, for all practical purposes by my self, my car from the ground up, the right way, using all the right parts, tools, and fresh drive train components. I didn't just slap in a new wiring harness, a complete used motor, leaking trans, and pray that it all works.
Next time you should try to know a little about a person before you try to make them look bad, because in situations such as this one, you end up looking like a clown :silly:
While as a 14 year old, you might think someone attempting to talk over her head is "owning" someone, unfourtunatley however, you'd be incorrectQuote:
Originally Posted by auriansmustang
HEY!!!!! Truth??? i just like those two smileys.Quote:
Originally Posted by Joe Friday
you're a asshole....Quote:
If you do all that work you say, then you would know the amount of work it took to build my car.
KEY WORDS= "PRACTICAL PURPOSES BY MYSELF" = WITH HELPQuote:
"MY CAR FROM THE GROUND UP" = you started with something right? and a LX stripped of all operational parts does not qualify?
"FRESH DRIVE TRAIN COMPONENTS" and I didn't huh?
ok, so I couldn't install my tv cable myself? no one can unless they're a experienced with the right tool to do it, if I would be stupid do it myself and was smart enough not to.
and the exhaust, I don't have a welder and can't weld and don't need to know how to weld.
and the headers, I worked 3 days straight in the FUCKING RAIN finishing my car, I really didn't feel like doing the headers when the shop was doing the exhaust anyway and I ran out of daylight!! I do have a day job you bitch.
any my tranny did not leak anythign you moron, and btw; the TV cable was installed wrong by the shop the screwed me.
clean up my mess? HELLO I GOT THAT BITCH RUNNING SO GO FUCK YOURSELF, how many girls you know that can swap an entire car? and you can't respect that?
REGARDLESS OF U TAKING THIS TOO FAR,
MY POINT WAS ONLY THAT PEOPLE DO WORK ON THEIR OWN CARS HERE
this isn't from the ground up huh?
what's left the dash and frame?
- Fuel:
- Fuel Injectors w/ fuel rail (done)
- Fuel & Return Lines (new location is passenger side vs. drivers side)
- 255 lph Fuel Pump
- Interior & Electrical:
- ECU
- Gauge Cluster (140 mph)
- Engine Wiring Harness
- Ignition Coil
- Starter
- Engine -DONE
- Breather Cap -DONE
- Water Pump -DONE
- Valve Covers -DONE
- Chrome Oil Pan -DONE
- Oil Pump -DONE
- Distributor Cap & Rotor
- a/c & smog eliminator kit w/ belt
- Alternator (painted Black)
- Accessory Brackets (painted aluminum)
- Motor Mounts
- Spark Plugs
- Thermostat
- Coolant Hoses
- Oil Filter & Oil
- Oil Pressure sensor
- Water Pump Bolts & fuel block plate for timing cover
- PCV plug/delete
- Vacume line
- Air: (2)
- Mass Air & BBK Cold Air Kit
- Lower Intake
- Upper Intake Plate
- Upper Intake
- BBK Throttle Body & spacer
- Steel Braided Spark Plug Wires
- Front Suspension, Rear-End & Brakes (pending...)
- Brake Pads & Rotors
- 8.8 Rearend
- Spindles
- Brake parts (calipers etc)
- Struts
- -MM Stut Tower Brace
-MM Subfame Connectors- but not installed yet
-Eibach Pro Springs & polyurethane isolators
-KYB front struts
-Tokico Performance rear Shocks
-MM K-Member Brace- but not installed yet
-MM Caster/Camber Plates
-Steering Rack Bushings- Tranny & Drivetrain Related Parts::
- Tranny Crossmember (V8 mounts further up vs the 2.3) -DONE
- AOD -Tranny Filter & Fluid
- B&M hammer shifter!!!
- Shifter Cable
- Torque Converter -DONE
- Flexplate -DONE
- TV Cable
- DriveShaft
- Cooling: (3)
- Upper Radiator Hose
- Radiator Bracket
- Lower radiator hose
- Radiator
- Radiator Cap? 14-16 psi
- Exhaust::
- Flow Tech headers
- Flowmaster cat-back exhaust force II 3 chamber
- H-Pipe exhaust
So you're trying to say that working on your car was hard? You have a job too......Boo fucking hoo, we've all busted our hands up, burned our selves, worked in the rain, got sick, all so we can see our project end well, you're nothing special.
Also a TV cable is a cake job,, I don't see where you'd have any problem installing something as simple as that.
But like I said, you're the one ending up looking dumb because you're trying to talk smack to someone with more experience than you, so on that note so I'll leave it at that and let you get back to your dream world ;)
PS. just an FYI You didn't get the car running, the shop did, you might of did a lot of work on it, but they cleaned up your mess ;)
no; the shop did not get it running- did you see my video? it didn't start there I finished it at home
and I don't give a shit about you being more experienced than me, that was not my point, you took my comment a little to personnal- I was only defending other people on GS and the knowledge and work they put into their cars, whether it be a little or allot-
:closed:
I for one give Nicole credit for doing what she did to her stang. Now Joe Friday, I don't think she was personally attacking your response...just stating that some of us on here DO our OWN WORK!!! Any time you'd like to come over and help on my LX...you're welcome....HOWEVER, you better have more experience than the mod listing on your site implies!!! If that's all you've got...you ain't touchin' my LX....too much money in it for hacking...I'll give you the benefit of the doubt that you just didn't list all your mods...cause a few bolt on body parts, headers, short shifter, gears and tuning does not make an expert...which you state you are.
Not trying to knock you....but don't stick that chin out if you can't take a shot!!!!
maco12
If all I had were those mods I woulden't be here talking shit about expierence, I'd jsut be another newbie around here without a clue. :rofl:
Nicole,
You dont have to explain yourself to this moron. Every single member of this site who has logged on in the past few months knows what you did, and what youve accomplished, and every one of them is proud of what you did.
This jackass can install a few bolt ons and he is suddenly a pro and knows everything. He is the one who should look around before opening his mouth. Most people on here dont turn their own wrenches hmm? so what exactly did you mean when you said...
sounds to me like we have all done it? atleast thats what you said??? >owned<Quote:
Your just a hater, and cant respect a girl who busted her ass on a project that was pretty much new to her. we all gotta start somewhere dont we? Ive done my fair share of engine swaps and drag car building from the "ground up". I know what it takes (are you gonna hate on me now? i dare you)... it takes hard work and dedication no matter what experience level your on...and 10 times more difficult when your just starting out. given the situation id say she did an outstanding job!
well come on shit talker...what exactly do you have done thats so freakin top secret? why isnt it listed on your site? what exactly makes you the car god that you are?
girlzgt, thx
nuf shit, this drama has gone far enough
yah it has....I just hate know it alls.
I vote for removal of this thread.
i give you credit for what you done, you're an awesome person, and shouldnt take that crap from anyoneQuote:
:j: :j:
:rofl: the butt hurt is out of control. It'll be okay, just take a deep breath and realize that it's the Internet. If you're going to try to start shit, just make sure you can take it back, if not you're going to get upset anytime you sit at a computer ;)
Just for you newbs, when I get home from work I'll update ye ole gs page, so you can see a little of my stang experience.
Just for you guys, I spent about half an hour updating the site
This has gone to far CLOSED
